🎉Community Raffle - Win $25
Join and Win
Part total strain energy
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Is it possible to compute part total strain energy for linear static sub case?
I can get element strain energy, but am unable to compute strain energy for whole part.
- Ashish
1 - 7 of 71
    Altair Employee
    OP
    Hi Ashish,
    Create a element Set for the part or component you are interested in.
    When you are creating ESE card in control cards, change ESE_V1 to SID and call the element set in SID.
    This will contour Strain energy for the elements in that particular component.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-07585700-1415680767_thumb.jp
    Altair Employee
    OP
    Hello Prakash
    Thanks for the reply!
    I got contour of strain energy for individual elements as per above method.
    What I need is the total strain energy for a part, with or without the contour for individual elements.
    Please see the attached image for elemental contour plot I got.
    In place of individial element, I require total part strain energy.
    The analysis has one part only.
    Thanks
    Ashish
    <?xml version="1.0" encoding="UTF-8"?>post-3200-0-94343200-1415684912_thumb.jp
    Altair Employee
    OP
    Ashish,
    when you plot for strain energy, change the Averaging method to Simple and check if that is what you need.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-52370400-1415687882_thumb.jp
    Altair Employee
    OP
    Prakash,
    I need to sum up the element strain energies to obtain  one value for total part.
    Please refer the following link:
    http://www.altairhyperworks.com/training/new_feature_videos/11/videos/result_math_PartTotalStrainEnergy_final/result_math_PartTotalStrainEnergy_final.htm
    In the video in above link, individual parts are isolated based on total strain energy, in place of element strain energy.
    That allows for part identification based on particular values (again, total strain energy).
    I require Total strain energy as that needs to be filled in another equation for subsequent calculation..
    Ashish
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    Ashish,
    The video in the link you provided also explains how to sum the elemental strain energies of a part to get the total strain energy of the part.
    Once in the expression builder, just use BCElemtopart, hide default arguments, enter straine energy and replace the syntax avg to sum.
    You can then quick query the component (right click > quick query > component) to display the value of each component.
    Altair Employee
    OP
    Hello Prakash!
    The simulation shown in video link is for modal analysis, while I am trying to get strain energy for linear static analysis.
    Further, the 'operator' tab in expression builder shown in the video link has Model as a drop down option, which I do not get in the analysis run I do for linear static.
    Is there some control card that needs to be applied to get such operator?
    Thanks,
    Ashish
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    Ashish,
    You must used the advanced result math template
    <?xml version="1.0" encoding="UTF-8"?>post-4438-0-61017000-1416822675_thumb.jp
