Altair RISE
Nominate Yourself Now!
a simulation with 1 GPU and run into a runtime error problem
User: "Yuan Tan"
Altair Community Member
Updated by Yuan Tan
Dear all,
I am running a simulation with 1 GPU and run into a runtime error problem just at the beginning (see screenshot).
Does anyone has an idea, why this is happening?
Thanks in advance for any replies.
Best regarss,
Yuan
1 - 8 of 81
    User: "Stephen Cole"
    Altair Employee
    Updated by Stephen Cole
    Hi Juan,
    It's possibly related to the GPU running out of memory.  Which version of EDEM are you using and which solver engine?  What kind of GPU do you have?
    Regards
    Stephen
    User: "Yuan Tan"
    OP
    Updated by Yuan Tan
    Hi Stephen,
    we are using EDEM 2022.3 and the GPU is NVIDIA GeForce GTX 10 Series
    User: "Yuan Tan"
    OP
    Updated by Yuan Tan
    Hi Juan,
    Regards
    Stephen
    Hi Stephen,
    Altair Employee
    Hi Stephen,
    Hi Yuan,
    I would expect that the GPU is running out of memory. The GTX 10 series contains a range of cards but they typically have low memory compared to the newer GPU cards.
    You can check memory usage during simulation to confirm, either by selecting the show "GPU memory usage" icon in the Simulator or via windows Resource Monitor you can see the GPU memory usage.
    Regards
    Stephen
    User: "Yuan Tan"
    OP
    Updated by Yuan Tan
    Hi Yuan,
    Regards
    Stephen
    Hi stephen,
    I can not even start the simulation, therefore I can not check the GPU memory. I have tried to select the icon, that  no data are shown. However, If it is this problem, how could I solve it?
    Acturally I have run the same simulation once, this error just show up when I change a contact parameter.
    Altair Employee
    Hi stephen,
    Hi Yuan,
    Does the simulation run on CPU, even for a few time-steps or another machine?
    It maybe that the simulation file is corrupt and setting up again may help, or if it runs on CPU for a few time-steps you could then stop the simulation and continue running from that point on GPU.
    Regards
    Stephen
    User: "satri"
    Hi Yuan, did you find a way to solve the problem? I am having this issue i am using nvidia rtx2070 gpu in edem 2025 version and i get same error. i dont have any problems running the simulation on windows but i am encountering this error in rhel 9. i am using CUDA solver
    User: "satri"
    I tried to set up the simulation again and i get same error. I dont have any issue with the api as it works well with windows.
