How to convert 1d element in Optistruct profile to Abaqus
Исак Ахмедов
Исак Ахмедов Altair Community Member
edited September 2022 in Community Q&A
Hello comrades!
I have some problems importing 1d elements from Optistruct to Abaqus. I have a task to convert a model with 1d T-section elements from Optistruct profile to Abaqus.
But there is a big problem with the fact that Hypermesh ignores the properties of the 1d element.
Is there any way to solve this problem?
Welcome!
Best Answer
  • Jason_Craanen
    Jason_Craanen
    Altair Employee
    edited September 2022 Answer ✓
    Jason Craanen, thank you for answer, but I may have misunderstood you. The problem is that the 1d section of the element is lost in the properties. For example, T (T1,T2) section is not converted automatically to BEAM SECTION and HMTSEC
    How to solve that?
    Thank you
    Abaqus does not have a T section equivalent, so there is no one to one mapping. You will need to reassign or recreate the beam section manually.
Answers
  • Jason_Craanen
    Jason_Craanen
    Altair Employee
    Hello,
    I would use the nonsolver sectiontype HMTSEC
  • Jason_Craanen
    Jason_Craanen
    Altair Employee
    Hello,
    Actually, I ran into the issue where HMTSEC is not supported for OS.
    My recommendation is to do a "soft conversion". Instead of running the convert tool, simply change the solver template to Abaqus.
    The property converts correctly, but will lose the beamsection. You can just reselect it and select the proper type.
  • Исак Ахмедов
    How to solve that?
    Thank you
  • Jason_Craanen
    Jason_Craanen
    Altair Employee
    How to solve that?
    Thank you
Welcome!
Welcome!
