Messages for the job:
*** ERROR # 23 *** SID 2 used on Case Control data SPC is missing in bulk data.
please help me with this issue
Please check the load collector with ID = 2.Maybe it is empty, or is missing completely.
please solve this issue i am following the same steps
i solved it twice
Constraint and pressure is placed in one collector.Move constraint from pressure loadcollector to Constraint load collector using organize command.
Thank you finally solved it
