Altair RISE
Nominate Yourself Now!
Error #941
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I am trying to do an encasing simulation but every time i launch optistruct, I am getting this error (ERROR #941); I tried changing the magnitude of the translation but it still doesn't work. Please help.
Thank you
1 - 5 of 51
    Altair Employee
    OP
    Hi @KBE
    Could you please share the model file, please to find the reasons for non-convergence.
    Altair Employee
    OP
    Hi Prakash,
    Due to the company confidential policy, I can not send you the file. However, I can tell you that I am try to encase two cylinders. See below for the config details:
    Contact Group:
    - DISCRET : S2S
    - TRACK = CONSLI
    - Property ID = PCONT
    PCONT details:
    - STIFF = SOFT
    - MU1 OPTIONS = REAL VALUE
            MU1    =  0.13
    - SEPARATION = YES
    - FRICESL_opts -- ticked
    After changing some things around, below is the current message I am getting.
     * Friction or STICK can cause more difficult nonlinear convergence - if feasible
       try frictionless gap/contact.
     * This problem has gap elements with friction or stick condition. For more
       intuitive results and often better convergence, set GAPOFFS on GAPPRM card
       to AUTO. (This may violate rigid body balance, especially for unsupported
       structures.) * This problem has elasto-plastic materials and the maximum plastic strain 1.10e+002
       is beyond the limit of small deformation theory. This may be the cause of
       non-convergence. Using fully integrated plastic elements may improve convergence,
       although possibly create overly stiff results.
    I look forward to your advice
    Thank you
    Altair Employee
    OP
    Hi KBE,
    Do you expect large/finite sliding interactions between the cylinders? If not, please change the TRACK field to SMALL.
    Also, add the below PARAM card and see if that helps
    PARAM,EXPERTNL,CNTSTB
    Thanks
    Vikas
    Altair Employee
    OP
    Hi KBE,
    Thanks
    Vikas
    Hi Vikas,
    thank you but that wasnt the problem. I already had PARAM, EXPERTNL and CNTSTB defined. I dont remember what it wad but I changed something in the PCONT card and it worked. I think i already posted my solution.
    Thanks again
    -KBE
    User: "FaroukM"
    Altair Community Member
    Updated by FaroukM
    Hey All;
    I had the same error : OptiStruct thinks that a contact problem, but I found that stiffness matrix (MAT9) is not stable ... and that's why the solver didn't converge.
    Best regards,
