Linear buckling analysis cannot be performed if the referential static loading subcase uses inertia relief。How to realize linear buckling calculation with inertia relief
Maybe nonlinear analysys using IMPERF could be an option. You can give it a try. IMHO Your load should be above the buckling point to determine the maximum bearable load.
Dear Gao Chen
IMHO
Kind regards Juergen
