🎉Community Raffle - Win $25
Join and Win
Tcl command to find the ID's of highlighted entities
User: "Ashwin Pinto_20677"
Altair Community Member
Updated by Ashwin Pinto_20677
Hello All,
I wanted to know if there is any direct command to extract the Id's of highlighted entities, Specifically in my case nodes ,
I have tried basic "hm_createmark" command but there is no option to retrieve/Add mark on highlighted entities ,
Please let me know if there any such option , Added an image for reference.
Thanks in advance
Regards,
Ashwin
1 - 3 of 31
    User: "Michael Herve"
    Altair Employee
    Updated by Michael Herve
    Hello Ashwin Pinto,
    if you do the renumber from the panel with the classic interface, you can get the command for showing the ids once the selection done:
    *createmark nodes 1 selection method
    *numbersmark nodes 1 1
    Best Regards,
    Michael
    OP
    Hello Ashwin Pinto,
    Best Regards,
    Michael
    Hell Michael,
    Thanks for the reply, But this command  "*numbersmark nodes 1 1" is used for displaying the Id's numbers and what I m looking for is a command to retrieve the highlighted node ID or add a mark on the highlighted nodes and then retrieve it.
    For example : There are commands to add mark on entities by either "-by Id" or "-by name",
    So, I wanted to know if there is any such command like select entity "-by highlight "
    Also I m able to highlight entities using (highlightmark node 1"high" ) command, but unable to find anything to retrieve it, considering I don't have the mark Id used for highlight.
    Kindly Let me know your thoughts,
    Thanks & Regards,
    Ashwin
    User: "Ben Buchanan"
    Altair Employee
    Updated by Ben Buchanan
