Altair RISE
Nominate Yourself Now!
Can you export faces with corresponding node ids from a model in HyperView?
User: "Jonas Kneifl"
Altair Community Member
Updated by Jonas Kneifl
Hi together,
I want to animate a model outside of Hyperview and therefore need information about the faces and the corresponding nodes/vertices.
Is it possible to export this information, e.g., in the form of a list of all node ids building a face?
Thanks in advance
1 - 5 of 51
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    what do you mean by 'faces'? do you need the element connectivity? (elements/nodes)?
    if yes, you can export them from HM easily, by using 'faces' command, and export displayed.
    OP
    Thanks for your fast response. Unfortunately, this is not exactly what I am seeking for.
    Face definition from Wikipedia: "In solid geometry, a face is a flat surface (a planar region) that forms part of the boundary of a solid object;"
    I tried to demonstrate it on the following picture:
    However, it is not clear which nodes of the element form a face from the element connectivity.
    Altair Employee
    despite of wikipedia's definition, people can think on faces as many different definitions :D
    anyway:
    can you describe what exactly do you need as an output?
    just nodes from a particular face? or coordinates as well?
    You can get this using a script, but you need to have a sample output file.
    The attached scripts could be tuned to perform what you need in HyperMesh/HyperWorks.
    You just need to use the 'by face' selection.
    OP
    Yeah that is true :D I hope that it is clear now.
    I just need the node ids of all faces.
    Supposing there are n faces with x nodes each, it could look like this:
    face node id 1 ...  node id x
    1 1 ... 3
    2 3 ... 5
    n 100 ... 114
    I would be very glad, if I could get this information with a script.
    Unfortunately, I'm not able to find your attached script. Where can I find them?
    Altair Employee
    1 1 ... 3
    2 3 ... 5
    n 100 ... 114
    sorry about that.
    now they're attached here.
    you could adapt these scripts to get what you want.
