Can you export faces with corresponding node ids from a model in HyperView?
Hi together,
I want to animate a model outside of Hyperview and therefore need information about the faces and the corresponding nodes/vertices.
Is it possible to export this information, e.g., in the form of a list of all node ids building a face?
Thanks in advance
Thanks for your fast response. Unfortunately, this is not exactly what I am seeking for.
Face definition from Wikipedia: "In solid geometry, a face is a flat surface (a planar region) that forms part of the boundary of a solid object;"
I tried to demonstrate it on the following picture:
However, it is not clear which nodes of the element form a face from the element connectivity.
Face definition from Wikipedia: "In solid geometry, a face is a flat surface (a planar region) that forms part of the boundary of a solid object;"I tried to demonstrate it on the following picture:
despite of wikipedia's definition, people can think on faces as many different definitions
anyway:
can you describe what exactly do you need as an output?
just nodes from a particular face? or coordinates as well?
You can get this using a script, but you need to have a sample output file.
The attached scripts could be tuned to perform what you need in HyperMesh/HyperWorks.
You just need to use the 'by face' selection.
Yeah that is true I hope that it is clear now.
I just need the node ids of all faces.
Supposing there are n faces with x nodes each, it could look like this:
face | node id 1 | ... | node id x |
1 | 1 | ... | 3 |
2 | 3 | ... | 5 |
n | 100 | ... | 114 |
I would be very glad, if I could get this information with a script.
Unfortunately, I'm not able to find your attached script. Where can I find them?
Yeah that is true
face node id 1 ... node id x 1 1 ... 3 2 3 ... 5 ... ... ... ... n 100 ... 114 I would be very glad, if I could get this information with a script.
sorry about that.
now they're attached here.
you could adapt these scripts to get what you want.
what do you mean by 'faces'? do you need the element connectivity? (elements/nodes)?
if yes, you can export them from HM easily, by using 'faces' command, and export displayed.
