Solver failed Hypermesh Radioss
Franco Porras Yarasca
Franco Porras Yarasca Altair Community Member
edited December 2022 in Community Q&A
Hi, I am new in Hypermesh. I wanted to run a simulation but at the first time it runned but I could not get any results. Then I runned to get results but then it showed: Solver failed. I can't find what is wrong in my simulation, could anyone help me?
I am using Hypermesh Radioss Block140
Thanks!
5x3.hm 170.6K
Answers
  • PaulAltair
    PaulAltair
    Altair Employee
    The HM file you attached seems to be completely empty?
    Version 140 is around 7 years old now, you should really try to use a newer version, technical support typically extends to 3 versions so the oldest version that still has technical support is 2020 (with 2021 and 2022 releases having occurred since then)
Welcome!
Welcome!
