🎉Community Raffle - Win $25
Join and Win
Elastic Sliding between two contact surfaces
Hi together,
i would like to connect two surfaces of two different parts. The contact should be able to slide transverse (with a specific Stiffness).
Is there an option to define this transverse stiffness in the PCONT options. Can i define it over Mu1? I am just wondering because Kt is calculated with the Equation Kt = Mu1*Stiff and Stiff is only a relative? Or is there any other way to prescribe a specific stiffness to the contact (and transverse)?
Do i have to enable the option FRICESL to enable the sliding?
Thank you for your help!
Sebastian
1 - 5 of 51
