Elastic Sliding between two contact surfaces
Altair Forum User
Altair Forum User
Hi together,
i would like to connect two surfaces of two different parts. The contact should be able to slide transverse (with a specific Stiffness).
Is there an option to define this transverse stiffness in the PCONT options. Can i define it over Mu1? I am just wondering because Kt is calculated with the Equation Kt = Mu1*Stiff and Stiff is only a relative? Or is there any other way to prescribe a specific stiffness to the contact (and transverse)?
Do i have to enable the option FRICESL to enable the sliding?
Thank you for your help!
Sebastian
Welcome!
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hi Sebastian,
    You ca provide stiffness  using STIFF_REAL_VAL on PCONT.
    Ofcourse Mu1 affects the transverse stiffness KT.  You can include FRISCEL>> AUTO this may help enable sliding.
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Thanks a lot for your response!
    Do you know what is the difference if i use the contact with FRISCEL and without?
    Best Regards,
    Sebastian
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hi Sebastian,
    If you specify a distance value,  the frictional force will be proportional the distance and linear.
    If it is a non zero value sliding will be based on transverse stiffness KT
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Thanks again!
    So if i specify a sliding distance in FRISCEL  of 5 mm the frictional force will grow linear. But at what slope? The transverse stiffness?
    What happens if the sliding exceeds those 5 mm? Or is the friction force at 5mm slide increased, so that the sliding distance can t exceed this value?
  • Altair Forum User
    Altair Forum User
    edited October 2017
    I need to check about the slope of the linearity.  I will get back to you ASAP!!!
Welcome!
Welcome!
