Help with Hexamesh 3D
Hi when I make I hexa mesh in a 3D form I make with the option 3D--solidmap---onevolumen--source type:quand and then mesh, like I saw in the tutorial but I think this is not the correct form to make it also because when I put on a propietie and I analyses said that there is missing propieties.
Thank you for the Helps!
Yes I can I put the propieties first I create a propiety, selecting the Material and the propity in this case PSOLID, then I go to collectors-- assign---Component_propity then I select the comp and the propiety that I have already created before and press asign.
That approach sounds correct. For finding the exact reason for your error messages I suggest that you contact your local support representative and provide them the .hm-file together with information on HM-version und HM-updated used.
Regards,
Stefan
The error is allways like this one:
ERROR: CQUAD4 element number 31 references
a missing or invalid property number 1.
ERROR: CQUAD4 element number 32 references
ERROR: CQUAD4 element number 33 references
ERROR: CQUAD4 element number 34 references
ERROR: CQUAD4 element number 35 references
ERROR: CTRIA3 element number 29 references
ERROR # 14 FROM SUBROUTINE renum
35 errors found in the input data.
***** FATAL INPUT DATA ERROR *****
***** FATAL ERROR ENCOUNTERED *****
And I don't really underestand why it said that I didn't put on the propieties or are missing...
Thank you for your helps
Gretting
Juanlu
Hi Juanlu,
You are shell and solid elements in the component. You assigned a solid property (PSOLID) to this component.
Please, delete shell elements in the component and the error message should be disappeared.
Regards,
Christophe
Hi,
could you please explain in more detail how you 'put on a propertie'? On elements or on components?
