Hello, I have some problem with setting of IMPVEL.
I need to procedure a repeated drop test analysis, so I created some floor.
for example, in the figure the blue floor is No.1 , and the red is No.2
In First step, I expect the ball drop to the blue floor and the red floor is move with the ball in a Zero relative velocity.
Therefor I created a Frame base on the ball, and set some IMPVEL load with the red floor and the Frame.
But actually the red floor is static.
Can anyone tell me what's wrong?
#attached is my input file and result.
