🎉Community Raffle - Win $25
Join and Win
Material Young modulus
User: "VAL1"
Altair Community Member
Updated by VAL1
To be accurate, Material's Young modulus is different according to pressing and pulling.
Can I set the two value for 1 material?
1 - 3 of 31
    User: "Pranav Hari"
    Updated by Pranav Hari
    Hi VAL1
    It is possible if you use an orthotropic material card.
    According to online help MAT 3 has the capability to apply youngs modulus in different directions.
    Have a check at the different card capabilities from the online help
    User: "VAL1"
    OP
    Updated by VAL1
    Thank you!
    I can use Mat3 for orthotropic ï»¿material.
    But I mean the attached file. in case of Al, If it is stretched 73GPa, pressing 71GPa.
    what card should I use in this situation?
    User: "GAJENDRA KUMAR NHAICHANIYA"
    Updated by GAJENDRA KUMAR NHAICHANIYA
    Hello VAL1,
    If you performing simple tension & compression individually, you can create two material with different E value. Make two prop & two loadstep.
