28335 code generation error message
Hi,
Anyone can explain the reason of getting the following error codes? Thanks.
Error Message:
Element: DLL_EXT_ESB Name: MainCCode
ERROR: invalid lvalue of assignment operation
ERROR: syntax error before or at line 203 in file 'C:\Users\KITCHE~1\AppData\Local\Temp\PsimTmp\script_2.cxx'
==>: fSSCB1 = !fGblTI_PWM1;
BUG: fSSCB1 = !fGblTI_PWM1<== ???
ERROR: invalid rvalue of assignment operation
ERROR: syntax error before or at line 204 in file 'C:\Users\KITCHE~1\AppData\Local\Temp\PsimTmp\script_2.cxx'
==>: fSSCB1_1 = fGblTI_PWM1;
BUG: fSSCB1_1 = fGblTI_PWM1<== ???
ERROR: syntax error before or at line 211 in file 'C:\Users\KITCHE~1\AppData\Local\Temp\PsimTmp\script_2.cxx'
