Enter a Material instead of a Property in DRESP1 volumefrac entry
I have a problem regarding the "volumefrac" Response Type in Optistruct optimization. In Previous HyperMesh/Optistruct versions (e.g. 2019) it was possible to enter a material instead of a property.
In the new UI of the HyperWorks 2022.1 version i can't find this option. If i enter a property the following error occurs:
I think that somehow the problem is, that my model consists of multiple components with a PCOMPP property. In 2019 Version i solved this error by entering the material in volumefrac DRESP1. Is there a solution also in 2022 version?
Thanks in advance and best regards
Lukas
1 - 1 of
11
Hi Lukas.
If you edit the text file by hand, can you make it run? What does it happen if you import the model back in hm?
