Altair RISE
Nominate Yourself Now!
Creating a Breakout model
User: "Crashphys"
Altair Community Member
Updated by Crashphys
Is it possible to create a breakout model in hypermesh? I want to take a part of a large model and analyse that on its own.
Thanks
1 - 4 of 41
    User: "Crashphys"
    OP
    Thank you for the info.
    Considering I have to import the displacement data, is it possible to create a refined mesh of the portion of interest too, or will it have to be the same mesh exactly?
    Thanks
    User: "Simon Križnik"
    Updated by Simon Križnik
    The nodes of the imported loads are equivalenced with those of the detailed model which are overlaying each other as a consequence of importing the free body loads. In the attached tutorial (HM-9010) this is done in step 10. I see no reason why it can't be done using displacement data.
    User: "Crashphys"
    OP
    Hello,
    I was following the tutorial HM 9010 up until step 8. When I get to the highlighted step, no loadcases are found. I did skip the first part because I am not interested in creating shear moment/potato plots and started from step 7. The tutorial said I could start from this point. If anyone has suggestions on what I might have missed please let me know.
    I would also like to know: When performing analysis on a cross section, how can I also enforce the displacements correctly? See the last two pictures attached: The first is a panel in my global model. The second is my panel in the DFEM (.fem files attached). I used the FBD->Forces tool to extract the loads on the section I want, however when I import those forces to my model via BC->Create->Forces->Interpolation, I end up with a ridiculous stress concentration in one part of my model. I'm not sure why this happens, but as far as I can tell there is no way to constrain the model correctly according to the global model. In the global model, all nodes are displaced a certain amount, but in the DFEM the nodes along the edge are forced to be constrained. Is there a way to ensure agreement between the two models?
