Type of Lattice structure
Hı,
I'm doing lattice structural optimizations. Lattice type 1 and 3 is working but 2 and 4 are not working. I get this error.
Can you help me?
Thank you.
Of course @Prakash Pagadala
lattice type 4 is used in this file. The solution is working when using lattice type 1 and 3 with the same parameters.
Hi,
Please try this file,
Somehow one of the fields on CONTACT card is wrongly formatted.
I understand what is a mistake. But I can't run when I try myself on the first model. Which did you change parameter?
Hi @Busra ASlan
I didn't change anything related to optimization. But I removed the badly formatted line on the CONTACT card.
Thank you for your answer,
But I don't understand. How can I remove the badly formatted line on the CONTACT card?
I am sorry, can you tell me more clearly.
Hi,
You can edit the deck in any text editor and compare the error message with Card image.
Hi,
can you share the entire .out file, please?
