Altair RISE
Nominate Yourself Now!
Modifying Analysis type of a Load Step
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello Everyone,
I am trying to find the right commant to modify the analysis type of a loadstep by a small script.
When I am looking for the cmd. file after doing this manually using the gui, I see the following command: *setvalue loadsteps id=1 STATUS=2 OS_TYPE=1
But nothing happens when I insert this command into my small code. No error message jumps up, but the setting of the analysis type will be not changed.
In the small macro I created it looks like the following:
*retainmarkselections 1
*renamecollector loadsteps 'loadstep1' 'temp'
*retainmarkselections 0
But the result is just the creation of the load step, but without setting the Analysis type:
<?xml version="1.0" encoding="UTF-8"?>56a8e156a380f_Analysistype.thumb.jpg.415
1 - 7 of 71
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    analysis type is stored in attribute #4060
    so you have to add this command
    *setvalue loadsteps id=1 STATUS=1 4060='STATICS'
    Altair Employee
    OP
    thank you
    Altair Employee
    OP
    Altair Employee
    OP
    Dear tinh!
    Thank you very much for the answer!
    I tried it, but actually nothing happened when running the command.
    I see the Analysis Type remains unmodified as it is to see in the upper picture.
    D o you have any further idea?
    Thanks in advance for your comments!
    Bests, David
    User: "tinh"
    Updated by tinh
    Hi,
    Perhaps new GUI did not write enough commands to cmf file
    you can still use old method to update analysis type
    -delete cmf file
    -enter panel loadstep, select 'temp' loadstep, switch analysis type to Linear Static > click Update
    - open the cmf file to get relevant commands (remember to remove '(', ',' and ')' by space)
    Altair Employee
    OP
    Pls help me the ways to setup the analysis method , constraint or Forece  in the Loadstep option by Tcl
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    You can do this through GUI.If you are commercial customer you can contact local hyperworks support for customization.
