🎉Community Raffle - Win $25
Join and Win
Change of material and influence on stress calculation in analysis
User: "johannesTUD"
Altair Community Member
Updated by johannesTUD
Hello,
I compared maximum stress of my model in a linear static analysis with different materials. I went from steel to 7075 aluminum (lower youngs modulus and higher cross contraction number). The rest of my model including the load cases stayed the same and i expected the stress to be higher in the case of aluminum because of its lower youngs modulus. But the exact opposite was the case. How can this be explained?
I did some research and found this quote in a PDF from altair (https://www.altairuniversity.com/wp-content/uploads/2014/02/postproc.pdf) : 'Changing the material will not require rerunning the analysis for stress (in case of linear static analysis) and a decision could be taken just by comparing the maximum stress value with the yield / ultimate strength of the material'
So i get different stresses in a linear static analysis with different materials, but this quote says an analysis rerun is not required. I am confused.
I highly appreciate if anyone has an explanation for this.
Thank you very much,
Johannes
