Radioss Implicit
Hi Datta,
In RADIOSS, both implicit and explicit time-integration schemes are available for the user. In an explicit scheme, velocities and displacements are obtained by direct integration of nodal accelerations. With this approach, the cycle time step is often small. Therefore, for static or slow dynamic computations where the duration of the study is long, many cycles are necessary to carry out the simulation. An alternative to explicit method in such cases is the implicit time-integration scheme. Not all explicit features are available for implicit analysis. In loading only Concentrated load /CLOAD, pressure /PLOAD, and gravity load /GRAV are available.
The user should provide the required control cards to activate the implicit scheme. When the RADIOSS solver is running an implicit analysis it will be shown in the out file as ** IMPLICIT OPTION USED **. The keywords required to launch a RADIOSS implicit analysis are defined in the Engine file and begin with /IMPL. In the Help Menu, please search for Activating an Implicit Analysis which will show the keywords required for an implicit analysis in RADIOSS. Examples are available in our Help Menu on implicit analysis. One tutorial and model files are attached along for your reference.
Hi,
It seems that we cannot use imposed displacement/velocity as loading condition while solving through radioss implicit. I was trying the same but was not working properly. I am using version 13 for the same. Kindly let me know about it.
Thank you
