🎉Community Raffle - Win $25
Join and Win
Which algorithm is used in FEKO 2023 for UTD solver?
sswh2User: "sswh2"
Altair Community Member
Updated by sswh2
Hi!
I want to know- which algorithm is used in FEKO for UTD solver? I have to use FEKO  for conformal antennas to see the effect of curvature, so I need to know first which algorithm of UTD is used in FEKO 2023.1  version. kindly help me by providing this information.
1 - 7 of 71
    JaehoonUser: "Jaehoon"
    Altair Employee
    Updated by Jaehoon
    Hello Srabonty,
    As you know, the UTD solver can not be solely used for the conformal antenna's placement simulations.
    I believe you are using the Feko's hybrid solution: Fullwave solver for antenna and UTD for surrounding geometry.
    For the surrounding geometry, you have two choices as shown below:  UTD and Faced UTD.
    You can find some details about two UTD solvers from the Feko user guide as shown below.
    Best regards,
    Jaehoon
    sswh2User: "sswh2"
    OP
    Updated by sswh2
    Hello Srabonty,
    Best regards,
    Jaehoon
    @Jaehoon Kim  sir thanks for your reply but I already read the feko manual as it is written FACETED UTD solver is used here,  my problem is which algorithm of UTD they used here?
    Altair Employee
    Accepted Answer
    Updated by Jaehoon
    Hello Srabonty,
    -> I'd like to share one slide excerpted from the Feko Antenna training material showing that Feko UTD can consider many different ray types (Direct, Reflected, Diffracted, Creeping,,,), which is also applicable for the faceted UTD, I believe.
    You can control the UTD's rays in the Feko solver setting as below. (Please click on "Advanced" in Ray contributions.)
    Regards,
    Jaehoon
    PS) Please let me know with some more explanation, if I misunderstood about your question.
    sswh2User: "sswh2"
    OP
    Updated by sswh2
    Hello Srabonty,
    Regards,
    Jaehoon
    @Jaehoon Kim  sir thank you for your reply.
    sswh2User: "sswh2"
    OP
    Updated by sswh2
    Hello Srabonty,
    Regards,
    Jaehoon
    @Jaehoon Kim sir - I am interested on the code/ math like for UTD in FEKO, Which numerical algorithm Feko uses to calculated diffraction from the curvature in UTD?
    Altair Employee
    Accepted Answer
    Updated by Jaehoon
    @Srabonty Soily  Definitely, your question is beyond my range, but the following paper is one of our developers' main references for the UTD implementation.
    Best regards,
    Jaehoon
    sswh2User: "sswh2"
    OP
    Updated by sswh2
    Hello Srabonty,
    Regards,
    Jaehoon
    @Jaehoon Kim  sir thanks! it's helpful
