Altair RISE
Nominate Yourself Now!
Quasi Static Non linear Analysis
User: "RAMGANESH"
Altair Community Member
Updated by RAMGANESH
Dear All,
I need to perform the Quasi Static Non linear Analysis for the below loading condition.
Time (sec)       Load(KN)
0                        0
25                  1333.33
55                  1333.33
Time (sec)       Load(KN)
0                        0
25                    4000
55                    4000
Load will be applied using actuator at two points, for that what contact to be created??
Please let me know the procedure for this analysis and provide your valuable guidelines
Thanks
RAM
1 - 30 of 331
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi Ram,
    You can run a Non linear direct transient analysis. You can use slide contact.
    For more information about NL direct transient analysis, refer to NL direct transient analysis section in OptiStruct user's guide.
    User: "RAMGANESH"
    OP
    Dear All,
    Any tutorial available for  Non linear direct transient analysis.
    Thanks
    RAM
    User: "RAMGANESH"
    OP
    Dear Prakash,
    As suggested by you did direct transient Analysis,but getting the following error.
    Generated slide contact with the attached parameters
    Please  give your valuable suggestions
    Thanks
    RAM
    Altair Employee
    Hi Ram,
    can you share the model file?
    Use this link to share the file: https://ftam1.altair.com/filedrop/~Ce4god
    User: "RAMGANESH"
    OP
    Dear Prakash,
    Shared the model,please check it and guide me how to solve this problem.
    Thanks
    RAM
    User: "RAMGANESH"
    OP
    Dear Prakash,
    Did you received my model???
    Thanks
    RAM
    Altair Employee
    Hi Ram,
    Check this example model.
    You are using Transient analysis type which ignore all non linearities.
    User: "RAMGANESH"
    OP
    Dear Prakash,
    I had shared the updated model similar to the model which you send .
    please check it and guide me.
    Thanks
    RAM
    User: "RAMGANESH"
    OP
    Dear All,
    While solving the problem following error occurs
    A fatal error has occurred during computations:
      *** ERROR # 4751 ***
      RBE1, RBE3 and mpcs are not supported in large displacement analysis.
     *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
    Please provide your valuable suggestions
    Thanks
    RAM
    Altair Employee
    Hi Ram,
    Which version of HyperWorks are you using?
    The error you see was a bug and was fixed. Try in HyperWorks 14.0 and let us know if you face any issues.
    Altair Employee
    @RAMGANESH
    FYi,
    You can check this tutorial on Non linear implicit analysis where load is imposed.
    OS-1500: Nonlinear Implicit Analysis of Bending of a Plate
    User: "RAMGANESH"
    OP
    Dear Sir,
    I had tried with the above tutorial ,but getting struck with the contact definition
    Thanks
    RAM
    Altair Employee
    Can you explain, please?
    User: "RAMGANESH"
    OP
    Dear Prakash,
    While generating slide contact between the seat model and actuator for applying the load ?
    The actuator profile is not getting impact with the seat model.
    Thanks
    RAM
    Altair Employee
    Ram,
    Can you share the updated model?
    User: "RAMGANESH"
    OP
    Dear Prakash,
    Model shared to your Dropbox .Please check it and guide me.
    Thanks
    RAM
    Altair Employee
    Hi Ram,
    I did not receive any file so far.
    User: "RAMGANESH"
    OP
    Dear Prakash,
    Thanks
    RAM
    Altair Employee
    Hi Ram,
    Contact surface normals are not defined properly. Contact surface normals of master and slave should face each other. This is not respected in your model.
    Please check and try again.
    User: "RAMGANESH"
    OP
    Dear Prakash,
    Contact surface normals means the element normal or some other thing ,please explain??
    Thanks
    RAM
    Altair Employee
    Ram,
    Not the element normals. I am checking if there are any other issues in the model. Will update soon if there are any.
    User: "RAMGANESH"
    OP
    Dear Prakash,
    I need to perform this analysis for 55 seconds with below two loadings.
    Time (sec)       Load(KN)
    0                        0
    25                  1333.33
    55                  1333.33
    Time (sec)       Load(KN)
    0                        0
    25                    4000
    55                    4000
    Thanks
    RAM
    User: "RAMGANESH"
    OP
    Dear Prakash,
    I have did the corrections in the contact surface normals as suggested by you and ran the analysis again.
    Same problem exists.. Please guide me
    Thanks
    RAM
    Altair Employee
    Ram,
    I will check and will update you soon.
    User: "RAMGANESH"
    OP
    Dear Prakash,
    Any suggestions?
    Please let me know
    Thanks
    RAM
    Altair Employee
    Hi Ram,
    Can you change the contact type to slide instead of using contact property?
    Also, create an RBE2/RBE3 and apply load through this instead of applying on nodes.
    User: "RAMGANESH"
    OP
    Dear Prakash,
    I applied the force directly to the model using RBE3 element and removes the actuator profile ,Contact definition .
    Then run the analysis,the following error occurs
    *** ERROR # 4079 ***
     Non-convergent nonlinear iterations for subcase 2.
     *** ERROR # 4002 ***
     Running RADIOSS engine, 1 ERROR and 0 WARNINGs have been detected.
     They are listed below.
     ENGINE ERROR:
      ** ERROR : RADIOSS IMPLICIT STOPPED DUE TO TIMESTEP LIMIT **
           ISTOP=-2
      NLGEOM subcase        2, engine finished
    (Running in-core solution)
     Volume                              = 1.21405E+006   Mass     = 9.56892E-003
                            ***** END OF REPORT *****
     For Useful OptiStruct Tips and Tricks, go to the URL:
    http://www.altairhyperworks.com/tips.aspx
     PROGRAM STOPPED DUE TO ERROR.
      ANALYSIS COMPLETED.
      *** SOME ERRORS WERE REPORTED DURING THE RUN,
      *** PLEASE VERIFY RESULTS AS THEY MAY BE INVALID.
    Thanks
    RAM
    Altair Employee
    Hi Ram,
    I ran a normal modes analysis to check the integrity of the model. I think there are few modelling errors.
    Couple of nodes from actuators have a strange behavior. Maybe try to remesh the actuator parts and re-run again.
    User: "RAMGANESH"
    OP
    Dear Prakash,
    I had tried with changes you said,same error occurs.
    Thanks
    RAM
    User: "RAMGANESH"
    OP
    Dear Prakash,
    When i am solving the problem with direct transient analysis without any contact definition by applying load directly to model,the problem is solved without any error.
    But while solving with contact definition in NLgeom analysis error occurs. Please guide me to solve this issue.
    Thanks
    RAM
1 - 30 of 331
