Composite: Linear static analysis - Tutorials & Tipps?
User: "Oguzhan Coban"
New Altair Community Member
Updated by Oguzhan Coban
 Hello everybody,  I am inexperienced with this software and generally with the simulation and analysis. I would be very happy to have your help.  I would like to perform a linear static analysis (stiffness). The model is a carbon fiber upper arm and i have the following questions:   Question 1: When I start HyperMesh Desktop 2019 an application called 'User Profile' opens and i have to choose one of them. Do you know which is the correct one to start in my case. (OptiStruct?) Question 2: I have access to connect.altair and altairuniversity. There are some tutorials which explain that you have to import the model into hypermesh but i cant find them. Do you know where they are? Could you give me some tipps for my Project?  In this regard, I want to perform the following steps: 1. Import 3D geometry from CATIA to HyperMesh (OptiStruct)  2. Define the geometry 3.Preprocessing of the composite • Modeling of the composite material • Create Laminate Modeling Concept • Design of composites with HyperLaminate • Define load and constraints 4. Perform analysis 5. Post-processing of the results  Best regards, Coban
1 - 4 of 41
