Hello everybody, I am inexperienced with this software and generally with the simulation and analysis. I would be very happy to have your help. I would like to perform a linear static analysis (stiffness). The model is a carbon fiber upper arm and i have the following questions: Question 1: When I start HyperMesh Desktop 2019 an application called 'User Profile' opens and i have to choose one of them. Do you know which is the correct one to start in my case. (OptiStruct?) Question 2: I have access to connect.altair and altairuniversity. There are some tutorials which explain that you have to import the model into hypermesh but i cant find them. Do you know where they are? Could you give me some tipps for my Project? In this regard, I want to perform the following steps: 1. Import 3D geometry from CATIA to HyperMesh (OptiStruct) 2. Define the geometry 3.Preprocessing of the composite • Modeling of the composite material • Create Laminate Modeling Concept • Design of composites with HyperLaminate • Define load and constraints 4. Perform analysis 5. Post-processing of the results Best regards, Coban
choose the Optistruct user profile. Here is a video on how to import geometry:
I recommend you go through FREE eBooks: Practical Aspects of Finite Element Analysis
Introduction to Practical Aspects of Composites with Altair OptiStruct
Check the following webinar:
Alo search for other videos related to composites:
https://www.google.com/search?q=composite+optistruct&sxsrf=ACYBGNSfNx5x1oRFY-AfexZKWyQXsUDT-w:1574068736682&source=lnms&tbm=vid&sa=X&ved=0ahUKEwj3n5v_tvPlAhWvlosKHTfYBU8Q_AUIEygC&biw=1858&bih=977
https://web.altair.com/altair-for-aerospace-learning-center
Thank you very much for your answers! But I am still struggling to import the CATIA Model to HyperMesh (Optistruct), although I am using the licensed version of CATIA V5. (Attached you will find a picture of the failure) Optistruct offers three composite modeling methods e.g. PCOMP, PCOMPG and PCOMPP. So I decided to use the PCOMPP composite modelling method, because it is a ply based method. Do you think it is the correct one? Thanks in advance! Best regards, Oguzhan
As per the message mentioned in status bar this import needs separate licence or try importing in other cad format.
