🎉Community Raffle - Win $25
Join and Win
Non liner quasi static analysis
User: "lerik"
New Altair Community Member
Updated by lerik
I want to apply a pretension in a 1D bolt and i need to define a new load step. I have seen in some tutorials that i should define a new load step with the type --> non linear quasi static.
I am using hypermesh optistruct 2019 and I don't know why I don't have this type in my options. I am doing something wrong? I have other options to define this bolt pretension?
1 - 9 of 91
    User: "lerik"
    OP
    Updated by lerik
    If I use the non liner static type, I have the following error:
    *** ERROR # 941 ***
     NON-CONVERGENT NONLINEAR ITERATIONS FOR SUBCASE 1
     Suggestions:
     * Large nonlinear errors indicate that the model may have insufficient support
       - check the data (ideally the model should be stable without gap elements).
       Or try stabilized version of expert system: PARAM,EXPERTNL,CNTSTB.
     I forgot to comment that I want to calculate the displacement between two surfaces (one with solid elements and the other one with surfaces) joined by a bolt and having a coefficient of friction between them.
    User: "FaroukM"
    Updated by FaroukM
    Hi Ierik,
    There is a nice tutorial regarding pretension.
    Please find it in the following link :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    https://altairhyperworks.com/hwhelp/Altair/2017/help/os/topics/solvers/1d_3d_pretensioned_bolt_analysis_of_ic_engine_components_r-1.htm#Z_1d_3d_pretensioned_bolt_analysis_of_ic_engine_components_r
    Cheers,
    User: "FaroukM"
    Updated by FaroukM
    *** ERROR # 941 ***
     Suggestions:
    Write to me if you need the FE model :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    User: "lerik"
    OP
    Updated by lerik
    Thank you for your reply Farouk Maaboudallah, the problem is that I don't have the non linear quasi static type in my panel options and as a consequence, I think, I don't have the CNTNLSUB entry. Do you KNow what can I do?
    Thanks
    User: "FaroukM"
    Updated by FaroukM
    Thanks
    Why you don't have it ?
    If you create a new 'Load Steps' you will not see Subcase Definition ?
    User: "lerik"
    OP
    Updated by lerik
    I only have this options. Can I do it with any of this types?
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.3150f9d9b9ab437b07aa44c48e6ecef0.png
    User: "FaroukM"
    Updated by FaroukM
    Yeah you have it. It's non-linear static (index 5x2))
    User: "Sachin_21833"
    Updated by Sachin_21833
    Hi, I'm running a bolt pretension analysis(nonlinear quasi static)But I'm getting this error. Error #4965 Maximum number of time increment cutbacks reached,analysis aborted, Any suggestions. Thank you Error #5905 Severe element distortion detected.
    User: "Adriano Koga_20259"
    Updated by Adriano Koga_20259
    there is something wrong with your convergency.
    It might related to a couple different factors, such as "pointy contacts".
    You need to give more details of your model, and share the .,out file.
    Also go though this post for some insights:
    https://community.altair.com/community?id=community_blog&sys_id=538764ab1b3790d4a5f742eddc4bcba4
