I need help with meshing
Karshenas Reza
Karshenas Reza Altair Community Member
edited February 2022 in Community Q&A
Hi
Are there any special resources like  Altair ebooks or tutorials for meshing methods to learn and use more effectively? generally I can do it properly but in some cases have some problems, so want to learn that better.
Answers
  • Brett Ramsey_20633
    Brett Ramsey_20633 New Altair Community Member
    There are some good resources under the knowledge base tab within the community. A lot of the examples are for very specific problems, but they showcase our tools and when and how to use them. Meshing is tricky because the "correct" mesh for a part depends on the type or analysis and the result resolution you want along with other things.
Welcome!
Welcome!
