Hi
Are there any special resources like Altair ebooks or tutorials for meshing methods to learn and use more effectively? generally I can do it properly but in some cases have some problems, so want to learn that better.
There are some good resources under the knowledge base tab within the community. A lot of the examples are for very specific problems, but they showcase our tools and when and how to use them. Meshing is tricky because the "correct" mesh for a part depends on the type or analysis and the result resolution you want along with other things.
