🎉Community Raffle - Win $25
Join and Win
"acuprep.exe has stopped working"
User: "Naresh_20479"
Altair Community Member
Updated by Naresh_20479
Hi
I am solving steady state CFD of a water jacket cooled motor.
when i click on solve , after few seconds a prompt as attached is displayed and the solution stops.
What could be the issue?
log file is also attached
1 - 5 of 51
    User: "acupro"
    Altair Employee
    Updated by acupro
    Can you describe what you are trying to model here?  It looks like you have 'air' and 'water' names in the volumes.  If you do have both air and water, are they entirely separated - no shared nodes between air and water volumes?  (Are there any walls with air on one side and water on the other?)  How big is the model (nodes, volume elements), and how much memory (RAM) does the machine have?  Have you done other models of this type successfully - and if yes - what has changed?
    OP
    The air and water are entirely separated by a metallic wall, No shared nodes.(Which means there is a wall with air on one side and water on other side)
     number of nodes : 480255
    number of elements : 2099278
    ram 32  GB ,    4 cores
    yes the model is done successfully earlier, now the change is mesh.
    The earlier model which is solved successfully has
    number of nodes : 830901
    number of elements : 3410774
    But the current model has few elements fail in tet collapse . Does it effect?
    Please tell me what quality parameters to be verified for CFD simulation.
    User: "acupro"
    Altair Employee
    Updated by acupro
    ram 32  GB ,    4 cores
    You mention a metallic wall.  Is that meshed with 3D elements - or is that just a zero-thickness surface with type = wall (or auto_wall)?
    In which interface (HyperMesh, HyperWorks CFD, SimLab, AcuConsole) did you create the model?
    Normally mesh element failure (collapsed, negative volume, etc) would be flagged/caught in AcuPrep, but I don't see any of those errors.
    If you are willing to share the model files (best would be the actual database - not just .inp and MESH.DIR) here, we could review, or you can contact your local support team.
    OP
    The wall is meshed with 3D elements(tetra).
    The model is prepared in HyperMesh.
    If to be shared, how do i securely share the input file with you.
    User: "acupro"
    Altair Employee
    Updated by acupro
    For secure share, I suggest you open a ticket with your local/regional Altair support team.
