Hi
I am solving steady state CFD of a water jacket cooled motor.
when i click on solve , after few seconds a prompt as attached is displayed and the solution stops.
What could be the issue?
log file is also attached
Can you describe what you are trying to model here? It looks like you have 'air' and 'water' names in the volumes. If you do have both air and water, are they entirely separated - no shared nodes between air and water volumes? (Are there any walls with air on one side and water on the other?) How big is the model (nodes, volume elements), and how much memory (RAM) does the machine have? Have you done other models of this type successfully - and if yes - what has changed?
The air and water are entirely separated by a metallic wall, No shared nodes.(Which means there is a wall with air on one side and water on other side)
number of nodes : 480255
number of elements : 2099278
ram 32 GB , 4 cores
yes the model is done successfully earlier, now the change is mesh.
The earlier model which is solved successfully has
number of nodes : 830901
number of elements : 3410774
But the current model has few elements fail in tet collapse . Does it effect?
Please tell me what quality parameters to be verified for CFD simulation.
The air and water are entirely separated by a metallic wall, No shared nodes.(Which means there is a wall with air on one side and water on other side) number of nodes : 480255 number of elements : 2099278 ram 32 GB , 4 cores yes the model is done successfully earlier, now the change is mesh. The earlier model which is solved successfully has number of nodes : 830901 number of elements : 3410774 But the current model has few elements fail in tet collapse . Does it effect? Please tell me what quality parameters to be verified for CFD simulation.
You mention a metallic wall. Is that meshed with 3D elements - or is that just a zero-thickness surface with type = wall (or auto_wall)?
In which interface (HyperMesh, HyperWorks CFD, SimLab, AcuConsole) did you create the model?
Normally mesh element failure (collapsed, negative volume, etc) would be flagged/caught in AcuPrep, but I don't see any of those errors.
If you are willing to share the model files (best would be the actual database - not just .inp and MESH.DIR) here, we could review, or you can contact your local support team.
The wall is meshed with 3D elements(tetra).
The model is prepared in HyperMesh.
If to be shared, how do i securely share the input file with you.
The wall is meshed with 3D elements(tetra). The model is prepared in HyperMesh. If to be shared, how do i securely share the input file with you.
For secure share, I suggest you open a ticket with your local/regional Altair support team.
