🎉Community Raffle - Win $25
Join and Win
Increasing Force or Displacement
Hi, i'm trying to model a 3 point bending in optistruct using a non linear quasi static analysis.
My objective is compare with a real test. I'm modelling a sandwich structure exactly with the properties of the honeycomb and the carbon fiber laminate.
The problem is that i want to use an increasing displacement like 2mm/minin the upper cilinder, the same as the real test. Is there any way to do that i already define the contacts between the cilinders and the plate?
Thanks in advance
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.21f419d0f460911d3aea6142095a85ad.png
1 - 2 of 21
