Hi, i'm trying to model a 3 point bending in optistruct using a non linear quasi static analysis.
My objective is compare with a real test. I'm modelling a sandwich structure exactly with the properties of the honeycomb and the carbon fiber laminate.
The problem is that i want to use an increasing displacement like 2mm/minin the upper cilinder, the same as the real test. Is there any way to do that i already define the contacts between the cilinders and the plate?
Thanks in advance
