Hi
I am new to AcuSolve.I am solving a problem where a hot fluid flows through a simple straight pipe and the pipe convects heat to the environment.
I have modeled the problem with Hex elements.but the results are not as expected.Heat interaction is not happening between hot fluid and the pipe except at the inlet and outlet . modeling with tetra elements also results the same.
All i want know is
1. if the hex elements can be implimented in ACUSolve or not.
2.The documentation is not available with me for ACUSolve and i cannot find what i wanted in the ACUSolve HELP.Suppose when i am activating Auto wall on , there are options like match mesh velocity , convective heat multiplier function, reference temperature multiplier function etc. This is just an example As i am new to ACUSolve i may need to refer a lot for What all these options exactly do and all.
Please advice me.
