🎉Community Raffle - Win $25
Join and Win
How to generate faces for 3d mesh with only selected nodes
User: "Akash Purushothaman"
Altair Community Member
Updated by Akash Purushothaman
In Hypermesh, I would like to generate faces for a component. The faces must be generated for only the selected nodes
Please refer image below
1 - 3 of 31
    User: "PaulAltair"
    Altair Employee
    Accepted Answer
    Updated by PaulAltair
    From General 2d Mesh Ribbon: you can create mesh 'by face' Does this do what you need?
    User: "PaulAltair"
    Altair Employee
    If you are using classic interface, the way I used to do it was to find faces on whole part, then either 'organise' only the elements 'by face' I need into a new comp, or if you want to just use the ^faces comp, delete elements 'by face', pick face you want, by elements 'reverse' and delete
    OP
    I understand. I am using classic interface. So I just wanted to know if there is any direct method. I will follow your suggestion. Thank you!
