Circle command delivers polygons
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I currently fail to create circles with the circle - center and radius command. Instead of circles, I get different types of polygons, depending on the radius I defined. Some Examples:
radius= 15 results in a line
radius= 30 gives a triangle
radius=90 is a quadrangle
radius=200 a pentagon and so on...
Is there probably something wrong with my preferences or units that I should check? Or has anybody else already experienced this problem?
Greetings,
Gottfried
<?xml version="1.0" encoding="UTF-8"?>post-37123-0-99174600-1430909716_thumb.p
1 - 2 of 21
    Altair Employee
    OP
    Hi Gottfried,
    Try this:
    1) Press ' O'  on your keyboard which takes you to the Options panel
    2) In options panel, go to graphics and change the graphics refinement to highest level
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-15863100-1430909994_thumb.jp
    Altair Employee
    OP
    Level 2 instead of level 1 already helped, thank you very much! I thought of this kind of settings, but was not able to identify them.
