creating series output-reg
Dear All,
For my problem i want to create one inlet and two outlets in series
For example: I want to calculate the flow in a pipe of 1m in that inlet is 5 bar and the outlet is ambient but i want to control the pressure in the middle of the pipe at .5m say 4 bar ( i,e 1 bar pressure drop)
How to set the boundary conditions for this problem ?
kindly provide your guidelines
Thanks
Ram
1 - 7 of
71
I am not sure if I understand the situation. What is meant by outlet in series? Is it like an interface surface between two fluid volumes? If yes you could probably do that with Element BC.
A snapshot might be helpful to understand your setup.
