run matlab script from Hypermesh makro
Hello,
is it possible to run a matlab script from a Hypermesh makro? What i want to do is
- setup modal analysis in Hypermesh
- run tcl makro, which executes the solver
- saving the pch file from the modal analysis
- run the matlab script (which imports the pch file and exports a txt file)
- import the txt file within the tcl script
- do some further actions....
Points 2-5 should all be done in the same makro. If it is not possible, how could you do that in another way (I dont know much about programming stuff yet)?
Hi,
to run matlab script from hypermesh, you should write the script to a *.m file, and call matlab.exe with that *.m file
set matlab "C:/path/to/matlab.exe"
set matfile "C:/path/to/script.m"
set matscript {
... do matlab calculations
set fpt [open $matfile w]
fconfigure $fpt -encoding utf-8
puts $fpt $matscript
close $fpt
exec $matlab -r [string map {/ \\\\} $matScript]
Hi,
set matscript {
close $fpt
you can use the command 'exec'. Take a look at Google for more examples.
Also you could use Compose to do this taks, as it already has a lot of CAE Readers implemented.
