🎉Community Raffle - Win $25
Join and Win
DRESP2 stress not equal with DRESP1 stress
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hy,
I would like to calculate a special safety value from stress responses, and using it in topology optimization.
The test of this calculation is started with a simple problem.
DRESP1 case 1:
- constaint: DRESP1 (von mises stress response, one selected element)
- objective: DRESP1 volume
DRESP2 case 1:
- only response: DRESP1 (von mises stress response, one selected element)
- constaint: DRESP2, (equation response) is calculated the following equation a(x)=x and using the DRESP1 von mises response
In this case the changes on design variables are the same, and the results are the same. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Than i changed the response element quantity to 2 and the DRESP1 and DRESP2 case results are different
I have tried to change constraint screening, nothing has changed
I have tried to look on sensitivity values, but no stress values included in *.asens files or *_topol.h3d files
I have tried to compare it with displacement response/constraint and they are good, so the DRESP1 and DRESP2 with 2 response nodes has the same results.
Is this problem connected to Stress-NORM aggregation ?
How can i turn ON Stress-NORM aggregation in DRESP2 case?
How can i examine the stress response sensitivities?
Did i miss someting in the setup?
I have attached the 2 different *.hm and *.fem files
Thanks,
CSR
1 - 2 of 21
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Please refer some information from online help for stress response.
    Altair Employee
    OP
    Thank you, Rahul!
    The document was helpful.
    I have tried out to set DOPTPRM, PNORM , 1 it means that the stress-norm calulates the average of the stress values divided by the response constraint value.
    The constraint value is 50, and the von mises result of the 2 choosen elements in the iteration 0 was 68.86 and 38.26 (from the results) so the stress norm value should be (68.86/50+38.26/50)/2=1.0712 , but in the output file this value is 1.377.
    Can you explain me the difference?
    I have attached, the *.hm file, so you can check it.
    Thank you again!
    CSR
