Minimum Tape Length Freesize constraint
Could someone please direct me to documentation relating to what the "minimum tape length" and "tape width" constraints in the composite tab of the free-size optimization options does?
full path in hyperworks 2020.1: Analysis -> Optimization -> Free Size -> Composites
Or more specifically, is it required that any tow generated by these options an integer multiple of the minimum length?
It seems to be the case, given the step-wise outlines of the element thicknesses:
Is there a way to set the minimum length, but have the maximum length be a continuous value?
When were these options added? every tutorial I seem to find online does not feature these constraints.
Additionally, what do the offset options: "LOFF" and "WOFF", control in this same tape settings tab?
Thanks!
