What is the meaning of this data in output file for Nonlinear transient analysis?
Hi,
I want to know the meaning of the data in output file for nonlinear transient analysis.
What is the meaning of ' itstp', 'norm(da)', 'noram(u_ref)', 'err_da', 'adjustment'?
'err_da' is error for what?
'itstp' is iteration step? then what is the difference between 'itstp' and 'Iter' ?
'Cutback' means that iteration does not satisfy the convergence criteria?
So increment load is changed?
In this, what is the meaning of 'Reduce next'??
what should be reduced next?
In this, what is the meaning of 'No change' ??
What should be not changed?
In this, what is the meaning of 'Enlarge next' ??
What should be enlarged?
Thanks
Automatic time-stepping is activated in your case. Please check the output section of attached document from online help.
