Altair RISE
Nominate Yourself Now!
Contact Force in HyperMesh
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I'm using HyperMesh and Abacus 3D Contact Solver in my project. This is a FEA Contact Simulations of two mating terminals, as shown below. Basically, terminal 1 will insert and withdraw during the mating process and terminal 2 was fixed at the right surfaces. I would like to plot the contact force between the two terminals during the insert/withdraw process. However, it is not available in HyperView. Can anyone help?
1 - 7 of 71
    Altair Employee
    OP
    Hi,
    In the output block you can request for contact force.
    Altair Employee
    OP
    Hello George, thanks for your reply.
    But I cannot see the options when I created output block:
    Altair Employee
    OP
    Hi,
    Which HyperWorks version are you using?. Ensure you are in Abaqus user profile.
    If issue persist please share the model file.
    Altair Employee
    OP
    Hello George,
    Thanks for your information.
    I'm using HM 14.0 and Abaqus as solver. Now I found the options for output block that you showed using Abaqus Standard.3d template. But the problem is, when I change the template, the Card Image for General Contact was also changed and the model doesn't run.
    <?xml version="1.0" encoding="UTF-8"?>change user template to standard.3d.JPG
    Altair Employee
    OP
    Hi,
    Is this a customized template you are using?
    Altair Employee
    OP
    Yes, it is a customized template for our company.
    Altair Employee
    OP
    Hi Taolue,
    Since this is a customized template we don't have any control on it.
    You can try solving the same in Standard 3d template.
