Contact Force in HyperMesh
Altair Forum User
Altair Forum User
I'm using HyperMesh and Abacus 3D Contact Solver in my project. This is a FEA Contact Simulations of two mating terminals, as shown below. Basically, terminal 1 will insert and withdraw during the mating process and terminal 2 was fixed at the right surfaces. I would like to plot the contact force between the two terminals during the insert/withdraw process. However, it is not available in HyperView. Can anyone help?
  • Altair Forum User
    Altair Forum User
    edited October 2017
    In the output block you can request for contact force.
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hello George, thanks for your reply.
    But I cannot see the options when I created output block:
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Which HyperWorks version are you using?. Ensure you are in Abaqus user profile.
    If issue persist please share the model file.
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hello George,
    Thanks for your information.
    I'm using HM 14.0 and Abaqus as solver. Now I found the options for output block that you showed using Abaqus Standard.3d template. But the problem is, when I change the template, the Card Image for General Contact was also changed and the model doesn't run.
    <?xml version="1.0" encoding="UTF-8"?>change user template to standard.3d.JPG
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Is this a customized template you are using?
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Yes, it is a customized template for our company.
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hi Taolue,
    Since this is a customized template we don't have any control on it.
    You can try solving the same in Standard 3d template.
