🎉Community Raffle - Win $25
Join and Win
GRAV card in Topology Optimization
User: "Vladimir_Gantovnik"
Altair Community Member
Updated by Vladimir_Gantovnik
Guys, quick question: can we use GRAV card with topology optimization or the applied load for topology optimization should be design variable independent? My required applied load is 50G. Thank you!
1 - 4 of 41
    User: "loistf"
    Updated by loistf
    I believe you can, but the question if it is convenient (computationally and optimization-problem-wise) is a differnent one. (and more complex, I guess)
    User: "Xiaolei"
    Altair Employee
    Accepted Answer
    Updated by Xiaolei
    yes, it's supported.
    Some statements I found from help:
    For mass penalization information when GRAV is used in a Topology optimization, refer to Design Variables in the User Guide.
    The polynomial penalization is active by default whenever mass influences the loading, for instance for normal modes, frequency response, gravity loading (GRAV) or rotational forces (RFORCE).
    Please check this link: https://help.altair.com/hwsolvers/os/topics/solvers/os/topology_opt_design_variables_r.htm
    OP
    Thank you! I will try to find example. During optimization with GRAV card the load value will change/reduce. So it is not usual topology optimization, where we apply loads and constraints on non-design parts.
    User: "shuxin"
    New Altair Community Member
    NOTE:There is no mass penalization when using the Polynomial penalization which is applied only to the stiffness
    Dose p always equal to 1.0 for load/mass ?
