ERROR 750
Hi Sanjog,
Please try with the attached file.
CAN YOU PLEASE TELL ME WHATS THE ISSUE?
Hi,
The issue was related with those elements specified in the out file. Those shell elements were in bad shape which resulted in null surface and were deleted.
Dear Sir,
Error 750
I am attaching file
Hi Did u check the element quality?
As Nachiket mentioned please check the element quality, especially check the element with id 2548 which seems to have a bad 'shape'.
You can try deleting this element and try running.
Can you please tell me how to delete that element?
Go to delete option (F2) and choose elems from the selector ,choose by id option, provide the element id and select delete.
THANKYOU SIR
