🎉Community Raffle - Win $25
Join and Win
Sizing
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hello everyone,
i have a different result for the fe-analyse for my surface modell which i want to use for sizing to the results of the fe-analyse of the solid model.
the result of the sizing is incorrect too...
so first i need help to make the same fe-analyse results and second for the correct sizing setup.
both models are below.
thanks for your help and best regards.
1 - 10 of 101
    User: "Simon Križnik"
    Altair Community Member
    Updated by Simon Križnik
    Hi,
    when the shell element size is small compared to thickness it loses validity. Solid elements are more appropriate for this object and you can perform shape optimization instead.
    Quote
    When h/L is large, shear deformation is at its maximum importance and the user should use solid elements. When h/L is small, transverse shear deformation is not important and thin shell elements are the most effective choice.
    https://www.linkedin.com/pulse/shells-vs-solids-finite-element-analysis-quick-review-kuusisto-p-e-
    Constraining the hole where loads are applied effectively eliminates this load. I suggest you perform inertia relief analysis (PARAM>INREL>-2) instead.
    Altair Employee
    OP
    Hey, first of all thank you very much for your reply.
    but i have a thickness defined in the property. and i can´t use solid elements because there are no solids..
    oh okay i never heard about that. the problem is that i have my deadline of the project soon and can´t deal with a whole new topic. what exactly is happening when i make (PARAM>INREL>-2)?
    i have make both analyses with (PARAM>INREL>-2) and the resuts are unfortunaly very different :/
    surface modell:
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.091fb864712c7a0ce64f6199af498c9f.png
    solid modell:
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.7083e95fad8be63a2eb5fa986313d062.png
    Glad to help.
    Perhaps there is still misunderstanding: shell elements can not be used for this object. Use the edited model meshed with tetra solid elements (or hexa/penta mesh) with solid property assigned. Define shape pertubations using HyperMorph and perform shape optimization.
    PARAM>INREL>-2 is inertia relief analysis. It makes possible simulation with no constraints, like satellite floating in space or aeroplane flying through the air. In your model it is best to use this option as the loads are applied to both holes at the same time. If you constrain the hole with load acting on that hole then this load will have no effect.
    9baaf37d9f5cfd48b775e83e396e3fb69a456522.jpg?image_play_button_size=2x&image_crop_resized=960x540&image_play_button=1&image_play_button_color=7b796ae0
    OptiStruct New Feature - Inertia Relief for LGDISP - Altair University
    Altair Employee
    OP
    thanks again.
    yes i know that. shell elements are only for the surface modell. and the surface modell is needed for the sizing.
    but i have to do the size optimimization. or is it possible to optimize the thickness with the shape optimimization. i´ve never did that before...
    what is the difference between -2 and -1 with support?
    okay thank you very much. for the background: the modell is a swing of an industral robot. the loads are the peak from the turning process of 90°.
    the result of the fem shows just 10 MPa under this load i think thats much to les...
    Kraft x [N]
    Kraft y [N]
    Kraft z [N]
    M x [Nm]
    M y [Nm]
    M z [Nm]
    LO
    -4545
    100734
    -1351
    82862
    -1788
    26811
    LU
    5191
    -85014
    1806
    -82867
    1772
    -26812
    Size optimization defines ideal component parameters, such as material values, cross-section dimensions and thicknesses. Shape optimization is different from freeform (topology) optimization in that it is used once the component’s topology has already been defined. Topology optimization is used to generate material layout concepts whereas shape optimization refines and improves the topology within the concept.
    In shape optimization, the outer boundary of the structure is modified to solve the optimization problem. Using finite element models, the shape is defined by the grid point locations. Hence, shape modifications change those locations.
    Size optimization can not be done with solid elements. Thickness can be optimized using solid elements by first defining shape perturbations and the performing shape optimization. Refer to attached videos and documents for more details.
    -2: Requests inertia relief analysis without the need for a SUPORT/SUPORT1 entry (automatic)
    -1: Requests that inertia relief be performed. SUPORT or SUPORT1 cards are required in the bulk data section to restrain rigid body motion.
    In the latest model you shared, each load is solved in separate loadsteps- maybe some of the loads are acting at the same time, which can cause higher stress. Have you done mesh convergence study?
    Altair Employee
    OP
    okay thanks for the information about shape optimization. but i would prefer the sizing because my prof said i should do that. is this possible to?
    no the loadsteps are time points while the robot is turning.
    the model (name: reanalyse interpretation) before was only with the loads of time point five because that one is the most critical.
    what is this? sorry i´m ery new with the programm...
    Again: shell elements can not be used to model this object, therefore size optimization can not be done. Modeling with solid elements and performing shape optimization will give optimized thickness dimension equivalent to optimized thickness of shell property in size optimization.
    About mesh convergence:
    https://enterfea.com/correct-mesh-size-quick-guide/
    If you plan to do a convergence check, consider performing at least one refinement of the model after the first run. If neighboring elements display large differences in stress, the gradient was probably not captured in these areas, therefore some mesh refinement is recommended.  In general, increasing the number of nodes improves the accuracy of the results. But at the same time, it increases the solution time and cost. Usual practice is to increase the number of elements and nodes in the areas of high stress (rather than reducing the global element size and remeshing the entire model) and continue until the difference between the two consecutive results is less than 5 to 10%.
    I recommend you to go through free ebook Practical Aspects of Finite Element Simulation (A Study Guide) which covers 9.12 Mesh Density And Solution Convergence.
    Altair Employee
    OP
    Okay.. but why can't i Use the surface Modell with shells? You say because of h/l but i definded a thickness of the Shell... i wanted to do it like  https://youtu.be/mfpDHfM4svQ
    Thank you very much for your Help!
    I will try to learn the shape optimization and the mesh convergence.
    In the surface model the thickness of shell is h=30-50mm and average element length is l=10mm, which gives ratio h/l=3-5. Thin shells are valid only when ratio h/l does not exceed 0.1, but in your model this ratio is exceeded by 30-50 times! Please refer again to the first post why this is invalid.
    Altair Employee
    OP
    allright, now my slowly mind has understood, thanks a lot for your patience!
