Error #186
Hello
I keep getting this message. I checked the load type more than three times for each of my load collectors to make sure they were set correctly. Is there something else that needs to be changed?
*** ERROR # 186 ***
An SPCD component must be constrained by an SPC or SPC1 data.
GRID ID = 25786
component = 2
LOAD set ID = 7
SPC set ID = 8
subcase ID = 1
Thank you in advanced
KBE
Dear tinh,
I have already created both SPCs and SPCDs on the same nodes. Which is why I dont understand why I am getting this error. I created a SPCADD and combined all mu SPCs. Then created a load step and defined SPCADD for the SPC and the SPCD for the LOAD.
For the SPCD, i put a displacement value of -50 on the y-axis, do I have to put that same value for the SPC? because for the SPC, I left it at zero.
Look forward to hearing from you
KBE
Dear tinh,
I rechecked my SPCs and SPCDs and re-did them. Now I am getting the error below.
Element # 16752, element type QUAD4.
ERROR - Validity limit violation: Vertex Angle = 197.47
upper limit = 180.00
*** ERROR # 2202 ***
Error(s) encountered during element check
***** Element Validity Check Failed *****
Element Quality Check Summary
Total # of elements that failed validity check (error) = 1
Note: Only element with the highest violation of each check is listed below.
Validity limit violations:
How do I find the element in fault?
Dear tinh,
KBE
Please create 1 loadcollector to store SPCs, select it as 'SPC' in loadstep creation
and one other to store SPCDs, select it as 'LOAD' in loadstep creation
the value on SPC can (should) be left zero, because you may use this SPC in other loadsteps,
solver will use value in SPCD only
Thank you Tinh,
I edited the mesh manually, grouped the SPCs and SPCDs and restarted, but now I have a different error. I am working with two cylinders. Trying to encase them but they are not convergent. I changed the displacement value to something greater and im still having issues.
Error #941
In the contact group, DISCRET is set to S2S and TRACK is set to CONSLI.
I await your respond
KBE
Hi tinh,
I found the error, it was not an issue with the contact group. In the load step (NLSTAT), the NLPARM card was under NLPARM instead of under NLPARL (LGDISP). So when I changed this setting, it worked.
Thank you for your help
Hi tinh,
I am just curious why OS raised an error about Contact?
Maybe because the contact is violated or not considered at all for a large strain problem running with a small strain formulation..?!!
I am suspecting...
ooh, I should have mentioned that I also changed the MORIENT in the contact group to NORM and in PCONT, I activated STFEXP. It was blank before.
That might have been the reason for the contact error. Not sure though because I am new to this.
Hi All,
i am also encountered the same error 186.
I have applied two loads in a single load collector (force and displacement). For applying displacement i have created as shown below.
I have defined SPC and SPCD as mentioned above. The selected nodes are same at both load collectors. Still i am facing the Error 186. Please help it out.
Hi
U have left DOF2 free, constrain it in SPC.
Hi
DOF for SPCD has to be referenced with SPC.
You can apply velocity/acceleration in any dynamic analysis like transient or frequency response analysis.
You need to use a special load collector TLOAD#/RLOAD# to specify the load type and load curve.
Please refer to the tutorial OS-T: 1310 Direct Transient Dynamic Analysis of a Bracket on how to apply a dynamic load.
It's because you created SPCD at some nodes (ex 25786) but did not create SPC there
please create both SPC and SPCD at concern nodes, values of SPCD will overwrite SPC in solver process
