Link do not rotate in motion view
Tejas
Tejas Altair Community Member
edited June 2024 in Community Q&A
Hello,
I am facing one problem in motion view four links  attached with respect to motion with each other. one spring transfer motion from fork to upper link cause it to rotate with revolve pair with blue link . But in simulation is is not happening, springs values are correct.
In below attach image for reference
Here in photo yellow colour link rotate wrt green colour link and green colour link is fixed with ground. the fork is rotate and causes to rotate the yellow link.
Answers
  • GTT Adam
    GTT Adam
    Altair Employee
    edited June 2024
    Hi Tejas,
    It's likely that the joint combination you have used is incorrect.
    Can you please attach you model so we can better understand what you problem is?
    Hope this helps!
    Adam Reid
Welcome!
Welcome!
