Powersim Product update version
Umberto Porcelli
Umberto Porcelli New Altair Community Member
edited April 2023 in Community Q&A
If I update version from 2021b to 2022.2 device create with before version can be transfer to new version or it's loss ?
This device must be recreate new in device of new version ?
regards
Answers
  • Albert_Dunford
    Albert_Dunford
    Altair Employee
    edited April 2023
    I assume you are speaking about thermal models?
    We switched the standard format from binary encoded .dev to a text based .xml format in 2022. That being said we can still import and use the .dev.
    Simply point to the folder where you have these files saved. options-set path, then device file path.
Welcome!
Welcome!
