Altair RISE
Nominate Yourself Now!
Optimise ellipsoid parameters on which to project nodes?
User: "Ingeniorator"
New Altair Community Member
Updated by Ingeniorator
Hello everyone,
my goal is to optimise the cell heights of a 3-dimensional lattice composed of 1D beam elements. The enveloping shape is already close to a 3D ellipsoid. The nodes on the lattice's layers are to be projected onto layered ellipsoid shapes (using the freehand mode in Hypermorph), positioned between the innermost and outermost lattice layers (think of onion layers, see example below of cuboid lattice morphed to ellipsoid function). Their parameters a/b/c need to be fed into Hyperstudy to determine their optimum values.
1. Can this be done directly at the parameters a/b/c level, or is this only feasible with shape/handle perturbations?
2. Furthermore, would it possible to determine the optimal nodal position (within a certain tolerance) tangential to a certain surface, without the nodes being associated to it? This would not need to be performed at the same time as the layer height optimisation.
3. As can be seen in the attached figure (open image in new tab for better quality), some node positions are irregular after morphing. This seems to occur even after applying a symmetry constraint. What could be the reason of this behaviour?
Any help is greatly appreciated.
